Tobers
- Andy
- No
I am trying to rig up a foot switch to trigger my remote behind-the-goal camera.
The problem is that making a connection on a cable plugged into the camera/flash socket of the pocket wizard plus ii only triggers the PW once when the connection is made, and once when the connection is broken, even though the connection is constant in between.
I had expected the PW to trigger continuously whilst the connection is made, in the same way as it does when the test button is held down.
The result is that my foot switch will only trigger two exposures rather than the required 10fps for as long as it is held down. The foot switch is not at fault. The Pw displays the same behaviour when a wire is used to make a continuous connection to the PW.
Any clues how to get the PW to do what I want?
Ta
Ta
not only that when you had fired off a burst & pressed the pedal down to stop it, if you released it again, it wouldn't fire until you had switched off the tranceiver, held the pedal down then switched it on again.
