Trailcam advice
Jelster
Steve
I have a fairly basic trail camera which I use primarily in the garden to capture footage of the hedgehogs. I'm lucky that we have about 4 or 5 individuals who come to my home made feeder most nights. 3 of them are easily identified and are visiting every night.
My problem is that the camera I have could be a lot better when on night vision mode. Also, it really suffers with the dew getting over the lens. So although it's a 1080p I would like a better/clearer image when in video mode. Another feature I would like, although not overly important, is the ability to "live view" so I can watch without disturbing them.
So, any suggestions as to what I should look at. I have a budget of up to £150.00
Pointing the lens slightly down and using some sort of motorbike helmet visor spray can help reduce the dew. Moving the camera a bit further away from the action can reduce the (usual) overexposure that the built in IR lamps often cause on relatively close action.
I've tried a spray, also the old fairy liquid trick (that we used to do on our visors). I don't think it helps that I like to get a low POV and of course, that brings it closer to the grass. When I used it 2 nights ago, anything past about 1am was useless as the lens looked like it was under water.
Edit: I have just thought about making a little lens hood for it. But I want something with better night time resolution anyway...
  • Like
Reactions: Nod
Lens/dew heater running off a power bank should resolve the under water pics
maybe try a gel hand warmer secured with an elastic band, lasts a few hours
You do get what you pay for to be honest.
I had one of these and it was superb - no 'live view' but good solid performance throughout the night and it keeps warm helping reduce any misting.
I have been using one of these for the past 18 mths (£150.00) and very impressed with them! Colour video at night and good quality images. - Don't let the name put you off!
They also have a different 4G Camera, if you want to view live.
I have also used 'Apeman' products for many years and the 'Bolygard' unit is vastly superior.
Never tried it on a camera but spitting inside your face mask and a rinsing it out seemed to work to stop misting on scuba gear, not a clue if it'll help with a trail cam. If you do try it let me know when, I could pop around and have a laugh... ;)
