Teleconverter help
foshan
Vic
I am looking for a teleconverter for my Tamron 70-300mm lens. As i am new to this could someone please give advice as to which one will fit. :)
Kenko, Jessops own brand, vivitar and other copies will fit but you will most likely only be able to use manual focus when fitted.
No point looking at the Canon versions as they will not work with your lens.
I've used a Kenko 2x TeleConverter with the Tamron 18-270 and can confirm that it's manual focus only unless at the very wide end. Even then it's a little slow to focus.
AF via LiveView will probably work fine, but that's probably not going to be acceptable depending on what you're doing...
thanks for all replies.I think ill save for a better lens:thumbs:
