Sync speed, canon 7d and Elinchrom d-lite rx 1, and skyport sync
coldpenguin
Am I expecting too much, or am I doing something wrong here?
I bought the two head kit, 280084 I think, it comes with two D-Lite RC One, and the Skyport speed transmitter.
I am using it with the Canon 7d, with the sync cable plugged into the transmitter from the camera.
I have set both heads to be mode r2,
I have pressed the test button on the transmitter untul it flashed twice
However, above 1/250s I am getting a slight black bar on the bottom of the frame, suggesting I am not getting a full sync.
Ah, I see the problem. An SLR only syncs at 1/250, however a compacy can sync at 1/1280? How come the SLR has a slower sync?
7D's max x-sync speed is 1/250sec. It's a limitation imposed by the focal-plane shutter, as found in all DSLRs.
There is a technique to go higher that works with many studio-type heads called Tail Hypersync but it's a bit of a bodge/hack with some major drawbacks, in particular, greatly reduced brightness and uneven exposure down the frame.
Any reason you need a faster sync?
No, I don't think so.
The 'model was a baby, so wasn't particularly happy about staying still, but 1/250s should be enough.
It is just that when I started to 'test' them, I had the kit set in non-speed mode, and the shots were disappointingly dark, at 1/50 (still object). (needed two heads 250Ws on a full power, 1/50, F-7 ISO 100, and it was still dark).
When I turned on the fast-sync mode (was off on both TX and flash before, which should have meant a 1/200 sync max), they were a lot better, power was at ~0.7 on each head out of 4.0, T 1/250, F-7, ISO 100.
I was wondering whether for some reason the camera is getting through the frame too fast (which it seems to be) when it shouldn't be.
This doesn't quite stack up ;)
Shutter speed makes no difference to flash exposure, so long as it's kept below 1/250sec max on a 7D. The flash duration is your effective 'shutter speed' and that's pretty nifty on a D-Lite One. There are some qualifications to that, and the 7D handbook says use 1/60sec with studio flash (p130). You can ignore that though, it's mega cautious, and rule of thumb these days is 1/125sec and that works fine with pretty much all DSLRs and all types of flash unit. In Skyport's non-speed mode.
There is normally no need to use faster shutter speeds than that in the studio - it makes no difference to the exposure and could, with some combinations of equipment, cause minor issues. However, you do have the option to go up to 1/250sec with your kit and that would be useful if the ambient light was high enough to influence the exposure - say bright sun coming through windows, or working outdoors. Then use the Speed mode, but it will drain the trigger battery more quickly.
No, I didn't think it did. Next time I have the kit out I will set it back to normal mode and try to recreate the problem. Difficulty is that the baby is now mobile, so I can't really leave the kit up without it being messed with.
