Studio White Balance
Studio lights are usually set to daylight. No need to set it manually. :)
You do need to set it manually - white balance is affected by the modifiers fitted to the flash and the colour/decor of the studio as well as by the flash itself, which varies make to make.
You set a custom white balance of the flash itself. Setting it to the modelling lamps would produce a very wrong figure, as the modelling lamps are generally around 2900K and the flash should be around 5500K
Thanks Garry. What if I was to increase the studio lights by adding another. Would the original reading still be ok as the flash would produce the same light colour?
Thanks,
John
If you buy a grey card and get the model to hold it in the first shot of any given lighting situation. If the modifiers change take a new card shot. In photoshop you use the white balance tool to get a white balance reading. A one click solution.
My bowens tend to shoot around 5300K so I set that on the camera and use the card to balance in post production.
Thanks wookie and everyone else.:)
john
