Russ77
- Russ
This one has got me stumped!!!
I have an HP Laptop running W7 which I've been able to plug in various USB devices, memory cards/readers etc without problem.
Tried using a new 32GB memory stick last night and all appeared to be OK, the drivers seemed to install and I could see the new removable drive in My Computer BUT it was showing total size 0b, available size 0b.
Thought it'd just need formatting but wouldn't let me do that.
Plugged it into my XP machine, fired up first time showing 29GB available and let me copy files to it. Tried it in the laptop again but the same thing happened as before.
Back to the XP machine, tried various formats but the same result on the HP Laptop. Saying that, occasionally it would let me open it up and look like it would allow me to copy files to it but the transfer rates were around 1MB/s.
I then tried it in the wife's W7 laptop, worked no problems. Finally I used a different profile on my Laptop and again it worked fine!
So..... there's something on my profile that stopping this USB stick from working BUT other USB sticks work just fine. I'm stuck!!!
I know it's probably easier just to use a new profile to copy data to/from the stick but it's the principle of the matter
Now I've come to work I have had one more idea..... I installed a Verbatim portable HDD and there was some softeware called "Green Button" which I believe auto ejects the drive if it thinks it's no longer needed. Could this somehow be stopping/ejecting the USB stick?
