Spigot Adaptor to turn my old tripod into a lightstand?
Rob.Marsh
Rob
Hi all,
Where is the best place to get a spigot similar to those on light stands that will screw onto a tripod quick release plate?
The reason I ask is because I have just got a new tripod and want to use my old one as a light stand/reflector stand.
Cheers,
Rob
One of these?
Three quid from Calumet for the Manfrotto version, mind you I'm sure I bought a whole extension arm from them (Calumet brand) with the spigot for about a quid more....
Cheers Flash,
Although I can't find the spigot pictured, only a manfrotto one that looks slightly different but seems to do the same thing.
If I still had access to a lathe I'd turn the b****r out!
Is this the extension arm you mean?
Yup that's the one, best to pop along if you have a Calumet near by and see what they have that will do the job
Unfortunately the nearest one is london.]
I am tempted by that extension arm now though, I could find plenty of uses for it. Is the spigot removable?
Yes, that's all I bought mine for, although now with some of the other things I've picked up along the way I could probably cobble all sorts of Heath Robinson contraptions up :lol:
Nice!
Thanks again Flash, on hand with the answer as always! :thumbs:
It's a male stud isn't it!?:shrug:
Yes, so the first spigot is probably the correct one - I can't actually remember which type came with the extension arms, but it probably wasn't the one Rob needs, although I guess that depends on the configuration of his old tripod :nuts:
