I've been testing an Energiser compatible battery from 7DayShop for the D5000 (same battery as D60). Absolutely no problems and bargin over Nikon branded battery.
I friend had a bad experience with another 3rd party brand, but I can't recall the name at the moment.
SD and SDHC are exactly the same thing; the HC bit just stands for high capacity, which means SD cards with 8/16/32gb capacity. They'll work in your camera
One thing with SDHC cards is that whilst most cameras can use them not all SD card readers can, you need to make sure that your card reader (if you use one) is compatible with SDHC.
