Dave Canon
- David
- No
I have found it infuriating that my A6600 can change settings so readily. Once set up, if you even lightly brush against the control Wheel, you may get a very different setting. You can also touch the screen with your nose if you use the viewfinder. In the last few days I lost several shots because the shutter was set to take 3 images 2 stops apart but this canceled itself. The next day it was on Auto ISO which then changed to ISO 32000. Never had such issue on my Canon DSLR. Does any Sony owner have similar issues and have you found a solution.
Dave
Dave
