Hi - I have been getting better results since I started using higher ISO and slower shutter speed to expose the background better when using a flash. I would prefer to use the lowest ISO possible in order to minimise noise. This means slowing my shutter speed down then. I read that the flash freezes action and so you can use a slow shutter speed. However, at some point surely the shutter speed is so slow that the ambient light hitting the subject causes motion blur. Is that right? Clearly I would raise the ISO before getting to this point - but how can i predict what the slowest shutter speed I can safely use is without suffering from motion blur?
I think you've got a pretty good understanding of the issues there.
In situations like that (low ambient indoors, longer speeds) camera shake is usually not nearly such a problem as subject movement, especially with IS which will run you down really quite long with a standard/wide lens.
Up to a point, a bit of subject blurring is good, and the flash will overlay a sharp stamp on it which often looks quite good, but that quicky desends into a blurry mess. Then, if you've run out of aperture and ISO options to keep the shutter speed up, you have to choose between either more ambient blur, or letting the background go dark with the flash taking prominence.
You just have to learn about movement blur. There is science to it, but it doesn't really apply in practise. For example, a car driving across the frame will blur very easiliy, but coming towards you much less, and at greater distance hardly at all. That theory is fine, but with people, hands and legs blur easily but that doesn't usually matter too much, but blurred faces are never acceptable.
If the room isn't too large, sometimes you can effectively supplement or even overwhelm the background ambient light by bouncing the flash as widely as possible, plus a bounce card or something for the direct flash element. Stofens are good for that, spreading the light fairly indescriminately but pretty much everywhere which is what you want. Most diffusers will do similar. You need a lowish ceiling and a powerful gun.
