I should have said I meant to shoot at f22 as I wanted that sunburst coming through the treeYour settings for this shot seem way off. F/22, 1/60th and ISO 1000 are nowhere near where you need to be shooting on a bright sunny day. You could make sure you're shooting a RAW file not a jpeg, expose for the sky and then bring the shadows up in post processing. Or you could use exposure bracketing, take 3 or 5 shots at different exposures and merge them in post processing.
That, I did not think of. Thank youI would certainly use bracketing and combine the shots in LR to produce a 32 bit HDR files.
Dave
Ah yes I suppose you need a small aperture for the starburst, hadn't thought of that. Just struck me as an odd combination of tiny aperture, slow shutter and high ISO. Definitely bracketing is the way to go. A modern high-end smartphone would probably take a better photo than your mirrorless here as they do all the multiple exposure bracketing for youI should have said I meant to shoot at f22 as I wanted that sunburst coming through the tree
Ahh, ok. I was just using ap mode so I could get that burstIt's best to shoot at base ISO as you increase your ISO you also decrease your available dynamic range. You have probably lost about 3 stops of dynamic range by shoot at ISO 1000.
