Sensor cleaning
siejones
Ok I need to clean my sensor those little dust devils have took residance and my blower won't shift em.
I want to have a go at shifting them myself but I am unsure of the best equipment/methods.
What products do you use and where did you get them from?
Eclipse fluid and sensor swabs m8, buy them from eBay or search here in the forums for alternative suppliers.
Eclipse cleaning fluid and Sensor Swabs (or make your own swabs from Early Learning Centre glue spreaders ;))
Full info and how to in this thread here :)
Hope this helps.
Yeah, basically you can either buy the following
Plastic Glue spreader, cut to size for yourself
Pecpads
Eclipse
or
Sensorswabs, from here. http://www.cameraclean.co.uk/acatalog/CCD_Cleaning.html
Or
the starter kit above (dont forget you'll need to buy the cleaning fluid too).
Basically sensor swabs and the starter kit are basically pecpads wrapped around the spatula already done for you. Depends if you want to make them yourself or not. Some do, some prefer them ready made.
Pecpads
Eclipse
or
Or
Thanks marcel as always a help to the photographic needy :)
The beginners kit comes with 10ml of eclipse fluid though :)
