Sd card For 6D
cargo
Gary
Hi just bought a 6d and want to play with the video options I use a 16gb class 6 sd/hd card.
On the best quality settings it will only record for about 20seconds. if I lower to quality to ipb 1920/24 it seems to be ok.So it is a faster card I require could someone tell me which is best to use. I have no idea if the quality set lower is very bad towards the higher quality.
Gaz
Hi,
Had very same problem with our Kingston cards, we bought Mymemory branded ones and they are fine, Fuji ones we have are fine also.
Try a low level format on your card via camera menu see if that helps before buying new ones. The problem is to do with the amount of day being written to the card and if it can't keep up them it automatically switches off.
Card details that work for us:
Mymemory 16gb Class 10 SDHC
Fuji 16gb Class 10 SDHC
Mike.
Thank you both. I ordered the scandisk.
Gaz
Will be faster for the photos too :)
Uodate: Card arrived today.Seems to work fine.Thanks again.
Gaz
