- Chris
I have a Plustek 7500i, of some vintage. Normally, it sits on my desk, plugged in to a power strip that just stays on, even when we're away. This time, I thought I should save some money and reduce the fire risk, so I switched the strip off (I've done this a few times before without problems). Having come home yesterday to find my AG-processed negs waiting for me, I wanted to scan them so, having switched the power strip back on yesterday (and other devices working fine), I pressed the power button on the Plustek. And nothing happened.
I've tried all the usual disconnect/reconnect, try a different socket etc, to no avail. The one clue is that the other power supply connectors on the strip are slightly warm, as they usually are, and this one was quite cold. So I'm guessing the power supply has gone bung.
For a bit I thought I might be able to use the power supply for my V500 (they both have the same round connector at the device end), but AFAICS the Epson is 24V and the Plustek is 15V (1.0A), so that would NOT be a good idea.
I did a search on fleabay for the part number (SYS1308-1515), and found this listing . It uses the same part number in the heading, but not on the device; however the specs look the same. Worth the risk?
