Hi Guys,
I hope someone can shed some light on this problem for me...
I currently use 2 Nikon D700 bodies with a SB-900 and a SB-800 as back-up.
Some strange things have been going on lately and the problem is becoming more regular.
Basically, I have them set-up using TTL but I am getting some totally random flash and sometimes multiple flashes. Sometimes the red illumination lights come on as well even though I have that turned off and the exposure randomly drops to -3 on the lcd.
Now when this has happened, I have turned the flash unit off and/or taken it out of the hot shoe and started again. These seems to fix the problem temporarily until something (probably some movement) makes it happen again.
When this happened with my SB-900 I thought I would switch over to my SB-800 back-up and it happened with that unit too!?
But here is the weird bit!... I thought then it must obviously be a problem with the hot-shoe, so I switched the flash(es) over to my other body, also a D700 and it happened on this body too. I have also tried different batteries too and haven't had problems with the same batteries in the past.
So I am now very confused as to whether this is a hot shoe problem, a mount problem, a power problem or a setting problem. There is nothing obvious that I have done so any feedback would be greatly appreciated.
It is def the strangest problem I have had over the last 5 years or so.
Cheers,
Jatz
Cheers,
Jatz
