Dr_O
- Dr Ozone
... (i'm getting over the EVF now!)...
I've seen some of those threadsshame seems to noisy to me iso 100 seems to start with noise and 800 seems very noisy, and at the end they also say not good for serious sports photography, even know they say that is should have better af then a dslr and has 12fps.
The light absorption of the translucent mirror would be a bit of a pain for me as I often use my lenses at max aperture. I guess if the advantages of not having a moving mirror outweighed the light absorption of the translucent mirror it would not be an issue.
You might still feel a bit robbed that your OEM 70-200 f2.8 wasn't giving you f2.8...
Be interesting to know how much light it does absorb as I seem to have only seen guesses although admittedly I've not looked that hard or it might not have registered with me. One comment I remember was 30% but that seems rather high??
This is difficult to quantify, Simon, as it depends on how sensitive the sensor is. An F2.8 lens is an F2.8 lens with all the characteristics of that lens. Looking at DXO figures, the Canon 7D sensor isn't particularly sensitive and is noisier than latest generation sensors but one would still say an F2.8 lens on it is still an F2.8. So far it appears that the A77 is similar in sensitivity, perhaps a smigdin less.
But the Nikon 7000D/Sony A580/Pentax K5, and I think the Canon 600D, are all more sensitive, i.e. they have lower noise floors and better high iso performance but that doesn't mean an F2.8 lens becomes an F2.5 when mounted on these cameras.
Sufficient to say, in my experience so far, up to and including iso 1600 the A77 performs very well, but it unquestionably takes a hit at iso 3200 and higher and I couldn't get anything like 24 MP of detail at these higher isos. With a bit of work I could probably get an ok A4 full frame print from an uncropped iso3200 image but not much bigger. Whether updated firmware can address this remains to be seen, but I don't think it'll overtake the latest generation 16/18MP sensors on noise performance alone. It's the price of having better resolution at iso 1600 and below. A fair trade off? Maybe, maybe not.
For static subjects there is the multi-frame trick where the camera makes use of its high burst rate, takes a rapid succession of high iso shots and combines them to get relatively noise free images. Most high iso shots aren't going to be of rapidly moving subjects in any case so this will be quite useful. The top iso in this mode is 256000 but a bit ropy, but begins to look quite detailed at 128000 and at 6400 is rather good.
If you want an honest and reliable opinion of a Sony camera, stay well clear of DPR. Their anti-Sony bias is legendary.
If you don't want noisy images don't shoot hi ISO!
Yes you are right of course and that said the A77 doesn't do a bad job when shooting RAW, I'm sure a few firmware updates to fine tune the in camera jpeg engine should sort things out to satisfy most.But I think the point is that modern semi-pro DSLRs are expected to have sensors with excellent high ISO performance...wedding photographers for example NEED high ISO performance to get their indoor shots and wildlife photographers NEED the ability to shoot ever longer lenses with fast shutter speeds in low light conditions.
To me this is a reflection of how photography and the technology we have is being pushed to the limits, something which wasn't perhaps possible in the film era.
That said, DXOMark have given the camera a decent enough high ISO score, up with the 7D of two years ago. This is pretty impressive given the 1/3rd stop light loss from the mirror. Less impressive, it appears from this review, is the JPG output. Whether that is an issue for the intended shooters is a different matter entirely.
I'm sorry, but that is nonsense. The Nex-c3, 5n and the A77 have all got high scores from DPR.
manualfocus-g said:I'm sorry, but that is nonsense. The Nex-c3, 5n and the A77 have all got high scores from DPR.
I'm not sure I understand that statement. It's a bit garbled. Are you asking why I don't need higher than iso 800?dont go above iso 800 for wildlife were do you live.
I've got one. OK, the fact that I laid out £900 for this little gem means that I'm hardly going to say I was suckered and it's rubbish but I'll share my experiences so far.
The sensor:
24 MP - who needs 24 MP? is the common question. Well, I can say quite categorically, it extracts more detail from most of my lenses, even the 18-70mm kit lens, and my 'G' lenses look staggeringly good.
High iso noise:
For a start, I always shoot raw so my judgement is based on the raw images. When viewed at 100% the noise does look a litle alarming at iso 3200 and above but with careful processing decent results can be obtained although some detail is lost. At iso 1600 and below it easily beats my A700, which with firmware version 4 is no slouch.
The A700 firmware took a couple of iterations to pull the best from its 12MP sensor, and I suspect the same will be true of the A77.
For now, my conclusion is that having a sensor that loses a stop's worth of noise at iso 3200 and above is a small price to pay for the sharpest APS-C sensor available anywhere up to iso 1600. One thing I have noticed is that there is considerably more detail retention in shadows than from my A700.
The EVF:
Moving from looking at a scene then to the viewfinder in bright sunlight takes a moment or two for the eye to adjust and is the biggest drawback to the EVF. On the plus side, it's a revelation to have seamless switching from screen based live-view to EVF, plus histogram, horizon level and other viewfinder options. And to actually see the white balance and exposure previews mirror what you're actually going to see on the photo is well worth the drawback. Stopdown preview is a bit of a waste of time with an OVF because the image dims so much that you can't see the DOF properly but with the EVF it corrects for this so you can easily see the differences that aperture changes make. In less bright conditions and indoors I barely notice that it is an EVF. It is much sharper than that in the A55.
Handling:
The handling still retains some of the feel of the A700 but with more tactile rubberised grips. It's a little lighter but still has a solid feel. There are plenty of buttons for instant changes, and mostly their placement is good. It's less of a 'brick' than the A700, but if you liked the A700, chances are you'll like the A77.
Performance:
Start up is quick and the fast burst shooting modes are impressive. Battery life is good although if you chimp a lot then it'll drain quicker, but I can easily expect a day's shooting from a single battery. Shutdown is a nuisance and takes an age, around six seconds. Like all Alphas the lens resets to infinity when shutting down so if you have a lens with a non-decoupled focussing ring attached you have to be aware of this.
Movies:
Full 1080p with continuous autofocus, and it works well. Quality is high. Caveats are that with full AF the AF system needs enough light to allow PD AF so the lens is automatically put to F3.5, or the lowest available whichever is the higher. To have full aperture control during shooting movies you can only have manual focussing. Before anyone complains, remember the competition has manual focussing or nothing. There is little or no problem with overheating of the sensor like in the A55. This is because steady-shot image stabilisation is done electronically. It clips a little around the sensor image then syncs each frame as it's saved to the card. It seems to work very well. Steady shot is the usual sensor-shift system when shooting stills.
@Dr O the 30% absorbtion of the SLT mirror is correct.
Any questions, I'll be happy to answer.
Mike.
They could hardly do anything else when the NEX cams outperform the (m4/3) competition by such a margin. For DSLRs they never give any credit for IBIS, compare noise performance at the native size (disadvantaging higher res sensors) and seem to deliberately ignore the fact that you can switch off things they describe as negatives (auto review on SLTs for example).
Actually, I don't think I made my point well about in body image stabilisation. It's fantastic that it's there and it's free, but in my experience in-lens systems are more reliable with better capability. If Sony made A mount lenses with in-lens stabilisation as well as offering IBIS, then it would be an incredible system in my opinion.
eccles said:I'm not sure I understand that statement. It's a bit garbled. Are you asking why I don't need higher than iso 800?
If so, I suppose you could turn it on its head and say that I've got used to going out in good light and not bothering if it's rainy and/or very overcast. Shooting short eared owls along the Severn Estuary at dusk might have been one example in the past where high iso would be useful but even then I've got away with iso 800.
Yeah sorry, im lazy and really need to sort it out.I think Scott mislaid a few '?'
I think he was suggesting that you either live somewhere with amazing light levels or you have f/1.0 lenses....![]()
