Hi
This resizes to a 1000px take a look I just upped all the size numbers in // Prep the image bit by 200px 800 became 1000 762 to 962 and so on I also changed the (C) to a copyright symbol in the original script, HTH Dave
// Add Image Data around the border of the image
// Photoshop CS Script
// First thing is to set up what setting will be used in the rest of the script
// but save them so they can be reset to what they were before this script is ran.
displayDialogs = DialogModes.NO;
var defaultRulerUnits = app.preferences.rulerUnits;
app.preferences.rulerUnits = Units.PIXELS;
// Define Colors
var black = new SolidColor();
black.rgb.red = black.rgb.green = black.rgb.blue = 0;
var white = new SolidColor();
white.rgb.red = white.rgb.green = white.rgb.blue = 255;
var BoarderColor = white;
var red = new SolidColor();
red.rgb.red = 255;
red.rgb.green = red.rgb.blue = 0;
var StrokeColor = black;
var AD = app.activeDocument;
PrepImage();
AuthorText();
ImageDataText(getExifData());
AD.flatten();
// END:Below are functions
// Prep the image
// 1. If image is greater then 1000 pixels, then size it down
// 2. Set to 72dpi
// 3. Create white poloriod type boarder around image for text
function PrepImage() **
// Set resolution to 72dpi for monitor viewing
var resRatio = AD.resolution/72;
if(resRatio!=1)**
AD.resizeImage(AD.width.value,AD.height.value,72);
// checking if landscape and if so, set width to 1000 and height to proportionate value
if(AD.width.value>AD.height.value)**
if(AD.width.value>1000)**
AD.resizeImage(965, AD.height.value/AD.width.value*962);
// checking if portrait and if so, set width to 1000 and height to proportionate value
if(AD.height.value>AD.width.value)**
if(AD.height.value>1000)**
AD.resizeImage(AD.width.value/AD.height.value*962,962);
// Create stoke by increasing the canvas size
backgroundColor = StrokeColor;
AD.resizeCanvas(AD.width+3,AD.height.value+3,AnchorPosition.MIDDLECENTER);
// Create boarder by increasing the canvas size
backgroundColor = BoarderColor;
AD.resizeCanvas(AD.width+35,AD.height.value+35,AnchorPosition.MIDDLECENTER);
// This function sets Author and copywrite notice to image
function AuthorText() **
var nameLayer = AD.artLayers.add();
nameLayer.kind = LayerKind.TEXT;
var TI = nameLayer.textItem;
TI.position = [AD.width.value - 5, AD.height.value - 25];
TI.contents = "Copyright © 2008 your name and site.com.";
TI.font = "Verdana-Italic";
TI.size = 12;
TI.tracking = 180;
TI.color = black;
//TI.fauxBold = true;
AD.activeLayer.rotate(-90,AnchorPosition.BOTTOMLEFT);
//AD.activeLayer.translate(-20,10);
// Sets Image info text to image
function ImageDataText(strData) **
//var tmpString = new String(strData);
var infoLayer = AD.artLayers.add();
infoLayer.kind = LayerKind.TEXT;
var TI = infoLayer.textItem;
TI.position = [20, AD.height.value - 5];
TI.contents = strData;
TI.font = "Verdana";
TI.size = 12;
TI.tracking = 50;
TI.color = black;
//AD.activeLayer.rotate(-90,AnchorPosition.BOTTOMLEFT);
//Check if a document is open
if ( documents.length > 0 )
var originalRulerUnits = preferences.rulerUnits;
preferences.rulerUnits = Units.PERCENT;
try
var docRef = activeDocument;
// Create a text layer at the front
var myLayerRef = docRef.artLayers.add();
myLayerRef.kind = LayerKind.TEXT;
myLayerRef.name = "Filename";
var myTextRef = myLayerRef.textItem;
//Set your parameters below this line
//If you wish to show the file extension, change the n to y in the line below, if not use n.
var ShowExtension = "n";
// Insert any text to appear before the filename, such as your name and copyright info between the quotes.
//If you do not want extra text, delete between the quotes (but leave the quotes in).
var TextBefore = "";
// Insert any text to appear after the filename between the quotes.
var TextAfter = "";
// Set font size in Points
myTextRef.size = 12;
//Set font - use GetFontName.js to get exact name
myTextRef.font = "Verdana-Italic";
//Set text colour in RGB values
var newColor = new SolidColor();
newColor.rgb.red = 0;
newColor.rgb.green = 0;
newColor.rgb.blue = 0;
myTextRef.color = newColor;
// Set the position of the text - percentages from left first, then from top.
myTextRef.position = new Array( 2, 2);
// Set the Blend Mode of the Text Layer. The name must be in CAPITALS - ie change NORMAL to DIFFERENCE.
myLayerRef.blendMode = BlendMode.NORMAL;
// select opacity in percentage
myLayerRef.opacity = 100;
// The following code strips the extension and writes tha text layer. fname = file name only
di=(docRef.name).indexOf(".");
fname = (docRef.name).substr(0, di);
//use extension if set
if ( ShowExtension == "y" )
fname = docRef.name
myTextRef.contents = TextBefore + " " + fname + " " + TextAfter;
catch( e )
// An error occurred. Restore ruler units, then propagate the error back
// to the user
preferences.rulerUnits = originalRulerUnits;
throw e;
// Everything went Ok. Restore ruler units
else
alert( "You must have a document open to add the filename!" );
// Sets image data to a string that will later be used to set into the image
function getExifData() **
// Get exif data from file
var exifData = AD.info.exif.toString();
// Use this function to put string into array.
// Returns tempArray
var exifDataArray = explodeArray(exifData,",");
// Get the info I want
for(n = 0; n < exifDataArray.length; n = n + 1 ) **
var stringTemp=exifDataArray[n]
//alert(n + ": " + stringTemp); //Show what's coming out of array
if(stringTemp.indexOf("Exposure Time")!=-1)**
var expTime = exifDataArray[n+1];
if(stringTemp.indexOf("Date Time Original")!=-1)**
var phoTime = exifDataArray[n+1];
var dateArray1 = phoTime.split(" ", 1);
phoTime = dateArray1[0];
var dateArray2 = phoTime.split(":");
var monthsArray =["January","February","March","April","May","June","July","August","September","October","November","December"];
phoTime = monthsArray[dateArray2[1]-1]+" "+dateArray2[2]+" "+dateArray2[0];
if(stringTemp.indexOf("Model")!=-1)**
var cameraModel = exifDataArray[n+1];
if(stringTemp.indexOf("F-Stop")!=-1)**
var fstop = exifDataArray[n+1];
if(stringTemp.indexOf("Focal Length")!=-1)**
var focal = exifDataArray[n+1];
if(stringTemp.indexOf("ISO Speed Ratings")!=-1)**
var iso = exifDataArray[n+1];
** // End of For loop
// Now take this data to produce a string
//var strTemp = new String("Image Info: "+expTime+" "+fstop+" ISO:"+iso);
//+"\u000DLens: "+lens+" Focal Lenth: "+focal+"\u000DDate photo taken: "+phoTime);
var strTemp = cameraModel + " "+phoTime+" "+expTime+" "+fstop+" ISO:"+iso+" Focal Length:"+focal;
return strTemp;
// Save File
function SaveJPEG(inFileName) **
var jpegOptions = new JPEGSaveOptions();
jpegOptions.quality = 9;
activeDocument.saveAs( File( inFileName ), jpegOptions );
//function below credited to 'bradles' over at the Adobe User to User forums.
function explodeArray(item,delimiter) **
tempArray=new Array(1);
var Count=0;
var tempString=new String(item);
while (tempString.indexOf(delimiter)>0) **
tempArray[Count]=tempString.substr(0,tempString.indexOf(delimiter));
tempString=tempString.substr(tempString.indexOf(delimiter)+1,tempString.length-tempString.indexOf(delimiter)+1);
Count=Count+1
tempArray[Count]=tempString;
return tempArray;
// Save File
var Count=0;
Count=Count+1
return tempArray;
