Remotes how far away do they work?
bigrob
Robin
Following on from Tony's Behind the goals thread I am just wondering what is the maximum distance you guys can get with your remotes.
Could you sit near one goal and have a remote at the other end?
Rob,
it really depends on the brand/model of the remotes you are using.
Pocketwizards have a significant range, and certainly enough to have a remote camera behind the goal at the other end of a football pitch, assuming you have nothing significant blocking your transmission to it.
I can't speak for the cheaper Chinese remotes although I once did a job with cheap remotes and failed to get a good reliable trigger from about 100ft away and so it could be an issue.
Either way you'd want to be sure you had a unique channel to ensure that you were tripping the shutter on it and not someone else ! Impossible to sort out mid-match. If you don't already have something then that might push you towards the Pocketwizard Multimax with a custom channel - depending on the number of remotes/photographers you typically encounter at a match.
From a logistical point of view you also need to think about being so far away from it from a security point of view and if you are able to get to it at say half-time to gain access to the card to be able to wire, and then there is the issue of how you trigger that remote camera.
Typically on a near goal remote you'll be shooting the action with a body and 70-200mm combination with the trigger on it - you'll get some/quite a few images which you'll just discard because there is no action but because you are predominately shooting goalmouth action only with it you'll get some with the ball in frame even if they are not perfect.
With the remote at the other end you really have two choices - stick the trigger on the body with the long lens (300/400mm) on it - which will result in a massive amount of empty frames as you shoot mid pitch action far away from the far goal-mouth OR trigger it separately on foot-pedal/by hand whilst shooting with the long lens to only get frames when there is goal mouth action you are interested in.
HTH
Thanks very much for that Mike.
I have just started experimenting with a 1D MKIIN with a 20-35
/2.8. Triggering that from the 70-200 with Photos Strato 2s. They are supposed the have a range of 150m. However I haven't tried it.
Nothing on this week so I may stick the triggers on the 300 next week at Millwall and see if they work.
At Millwall and Charlton where I shoot if the camera was nicked it would be another tog unless there was a pitch invasion..
I can't afford another 1D MkIIN and lens yet but thought it would great to have one behind the goal wherever I am and one at the far end.
I am seeing plenty of usage on the papers albeit Premiership of behind the goal cameras. Obviously not as much as 'normal' goals and cele shots.
I'll report back when I have tried it next weekend.
Robin, I have successfully shot from halfway line to remote behind goal. I am pretty sure I have been even farther away. I hesitate to leave my camera isolated at one end especially if its down the 'opposition' end. I'm pretty sure it would work, though. I use Yongnuos.
Tug I didn't have a game last weekend because of the international break.
I can try it beforehand at Millwall tomorrow. If it seems to fire okay I will leave it in position.
Update on Sat or Sun.
I got my Yongnuo RF603 triggers working at 200yards max. It varied a bit towards the longer ranges as it depends on the surroundings if anything was blocking the signal a bit. I tested it on a shooting range (didn't have a 200yard tape measure lol) me and my mate made in the mountains and the 200yard mark was as far as it worked, sometimes didn't though. It was a bit hit and miss. I think that's around 600ft or 180ish meters.
Yes they worked. I was on edge of the penalty area and camera at other end.
