Aaargh easels!
I have no idea how to work the ones that the darkroom I use has!
The ones I learned on had the frame that lifts up and at top left of the base there's slotts cut and you put a plate in to butt the paper up against, then the left and top margin are set by the frame that doesn't move, right and bottom you move the blades to set.
Ones in the darkroom I use now have all 4 blades moving, am I meant to just set the blades for the size of image then slap the paper in and trim it after?
