I got my DCR250 this morning and have been having a play
. It took me a good few attempts and a bit of reading on macro to get used to it, but I'm really happy with the results I'm getting. I don't have a tripod as yet, so the ISO is a bit higher than I'd like but other than that...so far so good! I have a few question about macro though:
1) how can I get closer
By using the Raynox on a shorter focal length, but if you don't really mean "closer", but mean "greater magnification", then you may find that the long end of your standard zoom plus the Raynox does that. It all depends on which of the focal lengths available to you give the nearest approach to macro without the Raynox.
2) what about flash? I can't get any satisfactory results with the built in one on my G3 - it's too harsh on shiny objects.
You must either use other lighting, or change the way your built-in flash illuminates the tiny thing. One way of doing that is to place a big white thing, such as a sheet of A4 white card, beside the subject, but out of image, and use your flash to light that and not the subject, which probably just means positioning and angling the white card to catch the flash, plus using something to shade the subject from the direct rays of the flash, which might even be your hand.
3) What sort of focal length/lens would I need to photograph insects etc? (Which is what I'd really want to do) from a decent distance without scaring them off?
Depends how skittery the insects are. lots of people find a 90mm macro lens. especially on a smaller sensor such as crop, works well. But the longer macro lenses get the more expensive. If you're thinking of a lens to put your Raynox on, then you want a lens with the best combination of long focal and nearest approach to macro size. That's a trade off strongly influenced by how much macro magnification you want, which you probably don't know yet.
I've got two macro lens, a 30mm and a 90mm. I've also got a Raynox. I thought when I got the macro lenses the Raynox would become redundant and I'd sell it. But I find it's very useful as a tiny extra thing to carry when I'm just carrying my camera around with one general purpose zoom with no particular purpose in mind, just in case something turns up that I'd like to photograph. Deals with those annoying moments when I would have said "Bother! If only I'd brought a macro lens!". I don't even have to change a lens to do a macro shot, I just clomp the Rayox on the end.
