RAW to TIF conversion software options
Paul-H
Hi Guys
Looking for a bit of software advice
I used to use a Fuji S100 shooting in RAW and batch converting to TIF using Photoshop SC3
I have now changed to the Fugi S200 and Photoshop RAW does not support the RAW files produced by the new Camera. Photoshops new RAW viewer only works with CS4.
I did try the RAW Converter withing Fuji's Finepix viewer software but that only does them one at a time with no batch conversion option.
So has anyone got any recomendations for a good fast batch converter that will work with the new Fuji RAW files in RAF format. (RAF to TIF)
Thanks for any advice.
Paul
Try IrfanView.
Edit: IrfanView hasn't been updated in a while. Along with many other programmes, it uses dcraw, which doesn't list your camera.
You could use thef ree DNG converter from Adobe. Convert the images to DNG and then import them into CS3. Bit of a roundabout tour, but incurs no cost. Plus the DNG converter batch converts any way so it can be left converting whilst you do something else
