duttytd said:No I take all my macro hand held.
What settings are you using?
Try aprature mode at about f11-f16
My setting is f/3.2 and shutter-speed 1/60 in Manual mode
fabs said:At those apertures, you'd need to use flash. In this case, Manual is usually the best mode as you will have more control.
Dogfish_magnet said:You'll need to use a lot smaller aperture (Bigger f number) if your shooting at 1:1, f3.2 will give you approx 0.03mm DOF where as f16 will give you approx 0.36mm.
Try manual focus , flash TTL , f11 - f16 , iso 200 , 1/200 and work from there
I thought that was obvious that you need to use a flash Tbh.
You'll need to use flash to get the best from any macro lens due to the small apertures you need to shoot f11 - f16 - Personally 95% of my macro is hand held
I disagree, flash makes a lot of things easier and is needed in some circumstances, but a lot of the best macros I've ever seen are taken with natural light on a tripod.
One of my favourite wildlife photographers shoot exclusively natural light and has one of the best galleries I've ever seen, just take a look at the macro galleries here:
Juzaphoto.com
And some of my own natural light shots:
Small skipper by Adamhawtin, on Flickr
Es-5955-2 by Adamhawtin, on Flickr
Tabanus sp. by Adamhawtin, on Flickr
(please click the top banner to see them larger, the downsizing makes them softer)
Dogfish_magnet said:There not macro shots ............. there close ups- and there a big difference.
Shot #3 looks macro to me
There not macro shots ............. there close ups- and there's a big difference.
.You'll need to use flash to get the best from any macro lens
You nor the OP never said you were sticking to the strictly accurate definition of macro, just .
But if you're talking strictly 1:1 then I partly agree with you, flash is much more useful than at lower magnification, but I still stand by my point that while useful and sometimes essential, natural light macros are possible and natural light will always look nicer when it is possible.
And duttytd is right, No. 3 was 1:1 or very close, not cropped.
Juzaphoto.com
Macro or not, they are pretty bland.
I do all my Macro shots handheld so I'm going to say no its not essential but its always going to be up to the user what they feel comfortable with its the same debate as the full flash, fill flash,or natural light.
And on the light subject I suspect a lot is down to your geographical location, what time of day you go out, the subjects you like to shoot and what magnification you tend to go for, and what kit you use.
Thank you all for suggestions. Does in built flash sufficient or do I need use external one. With in built I am getting under exposed pictures. Increasing ISO has little use.
No the built in flash is no good for macro
