michael kilner
- michael
I have just acquired a 2nd hand set of calumet genesis 200 strobes which came with 2 triggers and a hotshoe transmitter.When I connect both triggers and fire the flash only one head fires (both optical slaves are turned off).The flash that fires I shall call no 1 as it is the head which actually has sync written on it next to the port.If I turn off head one and fire the camera, head 2 will then fire but if I again power up both heads only head one fires.I get both heads to fire by turning on the optical sensor in head 2 and all is fine.I hope it is me being dim but I was under the impression that if both heads where connected to triggers via their sync ports then they would both fire whether the optical slaves were on or not
