Problems with loading Raw files in CS6
  • Thread starter Thread starter TG.
  • Start date Start date
TG.
Tel
Just wondered if anyone else is having any problems loading RAW files in CS6, it seems to take forever, and also if i try and import from LR4 it's the same, i never had this problem in CS5 or LR3, anyone got any idea why this is happening, maybe it's something silly like a setting a box not ticked, your feedback much appreciated, many thanks in advance :)
There are lots of moans online about how slow CS6 is in this respect. Most say they've gone back to CS5/5.5 as it's a dealbreaker on speed for them.
I'm also running CS6 extended with no speed issues, have you updated to the latest raw version? Also try checking if you have GPU processing turned on or off (edit/preference)
have you set the performance you use a good amount of ram.
Thanks, I've just upped it a bit, and it seems better now, Still not as quick as CS5 though, i didn't move the slider previously, as i'm running with 16GB of RAM on my PC.
Wayne yes i'm on RAW 7.1.0.354 and sorry i meant CS6 Extended, could you be more specific about what you mean have i got GPU processing turned on or off, as i may be looking at something different, thanks :)
Under the edit preferences is a performance tab, check to see if the gpu acceleration is ticked or not, this can cause issues, also are you using a scratch disk? Another thing that can cause speed issues is low disk space.
