Hi everyone,
I've haven't been a member of this forum for long but have really benefited from it as an complete amateur and reading through the various dicussions. I bought my first DSLR 2 months back, a Nikon D7000 and have been hooked on this forum ever since.
Right, the problem started when i bought a SB-700 so i could experiment with 'off camera flash'. I couldn't get my camera to remotely trigger the flash. I EVEN read the manual to make sure i had everything set right.
Menu : e3 - flash set to commander mode. Built in flash (BIF) was set to -- and Group A set to TTL. Channel set to 1.
The SB-700 was set to remote mode and. Group A and Channel 1.
Camera BIF fired a preflash but the SB-700 wouldn't fire. I tried the SB-700 on the hot shoe and it worked prefectly.
Remotely again, I then set the Group A on the camera menu to AA (Auto Aperture) instead of TTL - pressed the shutter release... this time the SB-700 beeped but still didn't fire. (high pitch-low pitch x 6)
Set the Group A back to TTL and this time set the SB-700 to SU-4 in the remote settings menu.
This time the SB-700 fired but seemed like it was mistimed (heard 3 beeps too) as it would not expose the image, even shooting almost directly into the flash head (to catch the light) the image never showed any light emanating from the flash unit. ( but the flash did fire as looking straight into it was almost enough to blind you when it does fire!)
Apologies for this long post.. theres a little more to go....
Next, on the camera menu, in commander mode, i set the built in flash (Master: to TTL instead of --) Group A still TTL. The SB-700 did not fire and more interesting was the 'built in flash' (BIF) fired but no where near enough to expose the image ( i suspect camera still trying to act as trigger only and not flash) . Even when the BIF was set to Manual and 1/1 power the BIF fired but not enough to expose the image.
Out of commander mode as a normal flash the BIF works perfectly.
Can anyone please shed some light (no pun
) as to what could be going wrong when the BIF is used on commander mode. Has anyone else ever experienced anything remotely similar with a Nikon or a D7000?
Any help would be GREATLY appreciated.
