Printing advice required " complete novice "
GR3Z
Graeme
I've just started photography a few months ago and have started to produce portrait pictures that I'd like to get printed, I've had some done at asda already and they looked crap, so I've recently bought a spyder 3 pro and cal'd my monitors, so I presume it's right my end.... Ive got my niece and nephew coming tomorrow and said I take some pics for my sis.... I'm aiming for the venture look and to get put on either canvas or acrylic...
I need to know the best way to resize, save file,file type, resolution etc etc and finally a good place to have them printed
I'm using PS cs5
Heres an example of my practice pics in another thread of the look I'm going for
http://www.talkphotography.co.uk/forums/showthread.php?t=356993
Cheers :)
Try saving as SRGB and send to DSCL or Digilabpro. Save as big a jpg file as your camera will allow (most are capable of printing pretty big). Not sure about canvas or acrylic but there are a lot of places that do that.
All high street labs assume you have sRGB - and if you save in ADOBE98 you'll get horrendus colour.
Also remember the skill level of the operators and supervisors in all chains will vary....
I am no expert, here is what I do/did though.
Actually, if you are a novice, I would suggest keeping the ISO as low as possible (don't know how young/active the kids are, but make sure that the shutter speed is enough to stop blurring). The lower the ISO, the less noise that the camera will introduce.
I would also suggest RAW shooting. Try and get as much as possilbe right in camera, (I like to go to the jpg tab and hit the increase contrast button in digital photo proffessional). Then just do a convert and save.
I suggest RAW, as if you don't quite get the exposure perfect (could end up with dark photos if you are trying to keep the ISO low), then you can recover slightly more in RAW than from a JPG.
Then I would recommend sending in to DSCL or another pro LAB, but, choose the option which is not Pro Pre Colour Corrected. The labs will then cast an eye over the images sent in, and will adjust them for you.
Only simple things, such as contrast and brightness, but it can help to recover a photo.
I asked DSCL for the correct profile to use on their Acrylics just last week, use the Lustre one (comes up as Frontier CP 2 I think).
(hmm, you are using photoshop, this has a camera raw import option, which can do a lot of tweaking that DPP can, and has an auto function which is reasonable). Just do Open on a RAW file.
Resolution, what size are you going to print. Aim for 300 Pixels per Inch.
IF you are going to edit much, then make sure that the resolution is the same, or larger than the final size you are going to print, prior to editing.
So, if you are going to do 12"x12", and your image is less than 3600x3600, then crop first. If however, your image is 5000x5000, you can crop (should crop) after your edits.
Select the crop tool, put in the size, 12 in 12 in for height and width, and 300 in the ppi box. Crop as per usual.
For DSCL, I believe that they prefer JPG. (attach the profile of course).
However, do not set the output profile, until you are going to save. So under edit, colour profile (convert), your profile should read sRGB, Adobe, pro photo or one of normal ones. These have 'more' scope for colours than a printer profile.
After a bit of editing, you go to View, Proof Setup, and then select the device which you are going to print on, This time Frontier CP 2. (for the lustre)
This gives you an idea as to what the image will be modified to when it is printed.
Save your PSD file in sRGB or whatever.
Then, just before you send it to DSCL, choose edit, convert to colour profile, and select the Frontier CP2.
(assuming you are already in 8 bit mode, or otherwise go to image, mode->8 bit, otherwise you cannot save as JPG).
Next, go to file, save, jpg, and there should be the option (already ticked?) about attaching the correct profile.
I do not save the PSD at this stage, I either use the history feature to undo, or revert to my pre-converted image.
When you upload to DSCL, I notice that the webpage preview does not match the colours correctly, I asked and this is know about. The preview is more for an idea of what you are ordering.
The people at DSCL are friendly, and responded reasonably quickly to emails. Also, given that acrylics are not cheap, I am sure (well, I did), that if you ask them to email you if the image is dire when they get it, that they won't mind doing that.
Hope it goes well
As cold Penguin said above ^^^^
Make sure you download the colour profiles from DSCL and convert to the required profile. This option is in Edit/Convert to profile. Will be under custom. The prints will change slightly and you can then re-adjust to taste. When you download the colour profiles just right click on then and select install.
Let us know how you get on.
Matt
That's Great news!!
Just had some myself arrive from DSCL
Ordered lunchtime arrive next morning.
Something different about actually holding the print rather than seeing it on your screen.
