stormcrow
- Dale
Help!!!!
I've recently bought a Pantone Huey Pro so I could calibrate my monitor this seemed to work ok but I have noticed that my pointer now has a pinkish tinge to it. I have re-calibrated 4 times now and I still get that pinkish colour to the pointer, I should add that I get very obvious whites in photoshop etc so it is not a general colour cast that is causing this.
Having done that I then went to pureprofiles.com and bought a printer icc profile off them for my printer and paper. This involved me printing out 2 test sheets via their detailed printing instructions then sending those to them so that they could scan the results and send me a profile based on the paper/printer & ink I used.
I've now received the profile from them installed as instructed in their again clear step by step instructions and done some test prints.
Problem is the prints are still clearly not what I am seeing on my monitor they are generally darker than what I am seeing and the colours are off as well.
Do you think this will be a problem with the profile or is it a problem with the Huey?
Is it worth changing to better calibration hardware such as a GretagMacbeth Eye-One Display 2, or a Spyder 3 ???
I should add I am not after perfection here, I just want to print photos for non commercial use, however I would like the prints to resemble fairly closely any subtle changes that I have painstakingly produced in photoshop.
Am I expecting too much from my basic Epson R360 even though it has had a custom profile made for it?
