You can also do the convert during the import so you don't end up with 2 copies of each file, the raw and the dng. Saves you a great deal of disk space.
Why convert to DNG?
I import a Canon CR2 RAW file into Lightroom and work with the CR2 RAW file rather than convert it to a DNG.
I dont get any options. I plug the camera in, fire up LR and then it just does it....
To me, converting to dng is an unnecessary extra step.I currently import directly from the D500 to LR and then LR converts the images into DNG.
Am I doing it right or should I change my method ?
You have the choice of copy files or copy as DNG files.
https://helpx.adobe.com/lightroom/help/importing-photos-lightroom-basic-workflow.html
Not quite true.DNG is an open format so years down the line will still be able to open them in any editing software
Not quite true.
DNG is an ADOBE format, so it will be able to be opened by Adobe editing software.
An "Open format" is one where the details are published and freely available, which is definitely not the case with Adobe, who keep the details of DNG a closely guarded secret.
That's the difference between "Open Source" and open format. True Open Source files are published and available for update and modification by anyone.Not quite true either.
Adbode licence the format (free of charge) for hardware and software manufactures to read and write to the DNG format. It can't be a closely guarded secret if anybody can read and write to the format.
Me too.The only advantage, to me, of DNG is to save disk space / improve load times. But it's very marginal, so I just keep, the Nikon RAW files. If I ever wanted to archive more efficiently, I suppose I could convert to DNG at that stage, but disk space is quite cheap so don't think I'll ever do it.
Some good points there, especially section 4.
Interesting. I'm now reviewing my use of DNG in the light of this and other articles.
