portable power supply for mobile phone
KIPAX
Seriously Likeable
KIPAX Lancashire UK
I ahve a motorolo g
i can see on ebay loads of power supplies that you could take out wiht you if no access to a proper plug say.. but theres so many
anyone reccomend a god one?
Being kind of sensible - I've just bought http://www.amazon.com/dp/B00LAEBJNM/ref=pe_385040_30332200_TE_item on the recommendation of a friend in the USA . Well I'd a pal over in the US so got him to order it up for me. It's very nice and has a massive charge. I've bought it as I've just got new hearing aids that I can control settings by using an iTouch. Since the settings are changed by Bluetooth I'd no idea as to how long batteries would last so felt that something like that could be useful
Use an anker astro3e battery here, very useful!
I'd say any of the batteries recommended will do the job just fine. As long as they have at least 10,000mAh capacity (obviously more is better) and can fast charge the devices you want to use them with, then they'll serve you well.
One thing to bare in mind is that on your standard 2A charger, a dead 10,000mAh battery will take approx 5 hours to charge, more if it doesn't have fast charging input itself, or it's bigger, or your charger is smaller!
I have an Anker, either 10Ah or 12Ah (can't remember). Does the job admirably.
Another vote for Anker, I have two and either will fully charge a Nexus 7 twice with a bit left over before needing charged themselves.
