Photoshop & copyright placement help
Bletch
James
Hi guys
I can't for the life of me remember what shortcut to use when dragging a layer (containing my name) onto several photos and having it appear exactly in the same place on each and every photo ie bottom right corner. I thought it was hold 'shift' and drag the layer on to every photo but it doesn't work anymore :( Anyone help please?
Haven't done it for a while, but here goes.
To center a layer while copying it to another document, drag from the layers palette to the other document, but hold the Shift key down while releasing the mouse button. If both documents have identical dimensions, instead of centering, the copied layer will be placed in the exact same position.
...and that worked! Thank you Carol :)
