Photomechanic 5 to Camera Raw 11
snowkate
Hi All, working from Photomechanic 5 to Camera Raw 11 for use with new FujiX-T3. Is there a way to select the RAF files only for edit in Camera Raw when I have shot both raw + jpg? I have tried 'arrange by' but it doesn't work. If I select the images in Photomechanic that I want to edit in Camera Raw it opens the jpgs in CC Photoshop instead of opening the RAF files in Camera Raw. Any help appreciated!
I can't help, as I have never taken RAW+JPEG and not experienced an issue and there doesn't seem to be any obvious settings in the preferences. The PhotoMechanic support forum is very good, so if no one else can help you here, I would try across at their forum
Sure.
Preferences....Launching....
And then, "when in raw+jpeg mode, editing a photo will" and choose if you want to edit the jpeg or raw. You can also set an editor per file type. So you could e.g. edit jpegs in Photoshop and Raws in Capture 1.
Sure.
I completely missed that when I had a look for snowkate :-(
