Hello All
Just wanted some help on this. I tried to take some panoramic shots today but noticed I failed miserably when I saw them on the monitor :bonk:
Can someone give me some tips??
I mounted the camera on a tripod and start shooting so the photo will overlap slightly. I only tried 180 degrees to start with!
My main problem was each picture had a slightly different lighting to each other. Some were not too bad but there was 1 that was way too dark. Even if I sorted the lighting out in photoshop, some of the object just wont join up (say a car, when a picture ends on a car, in the next photo the car will be bigger/taller or higher/lower :shrug
I think the main reason for the bit that wont join was because I used the sigma 10-20 @10mm so the picture was distorted!! but I just want to confirm it really is this.
How do I get the same lighting thru out the shoot?
Do I only shoot in mild lighting??? (my shoot today was sunny) what if my only chance was a sunny day?
Which mode should I use and what setting?
I would really like to do one of these as I have seen some amazing work on here!
