The lens can be much less significant though, if you're happy with a smaller lens.
Compact Camera Meter
Compare unlimited number of cameras with lenses, see how compact or bulky a camera is and sort by height, width, depth and weight.camerasize.com
Much more significant if you're not
Not many people are going to weigh in that sort of cash for a camera to only use it with a small relatively slow prime
Well I did and the image quality an A7 and a small relatively slow prime like a 35mm f2.8 gives will easily exceed that of a MFT camera and 17mm f1.8 and the costs of a FF set up could well not be discouragingly over expensive as MFT is hardly a cheap system these days.
If you have a SLR style MFT camera and fit any lens to it it's a size and weight which needs to be in a bag rather than a pocket and once you're taking a bag the additional difference in bulk and weight of a fairly compact FF body and lens is IMO not all that significant.
I mostly use prime lenses in the 17 to 85mm range and also have a 28-70mm kit zoom and any of my lenses on my Sony A7 makes for a combination that isn't significantly bigger than the last MFT SLR style camera I had, a Panasonic G7. This is why I no longer have MFT SLR style cameras, because unless you're using lenses that tend to be a lot bigger on FF like long lenses or some of the heftier wides or primes there's no real significant advantage for MFT over a smaller FF camera. Even the MFT RF style cameras are really only a grip and EVF hump smaller than my A7 which is why my MFT kit hardly gets used these days except when I want to use my 100-400mm lens or want to shoot with a silent shutter.
I think for wildlife users the size difference is considerable, and looking at the Oly thread there's a lot of wildlife shooters posting, not necessarily saying that's the normAs is anyone who buys any of this kit from MFT and up through FF.
The point is that a small FF camera need not be prohibitively large compared to MFT and the smaller FF systems demonstrate that. Only a minority would argue otherwise and those using larger lenses which would make a more significant difference are a minority within the interchangeable lens camera minority. Some people even think that these cameras need to be bigger.
