- Stephen
A long time ago, in a thread far, far away (apologies to George Lucas), specifically here
www.talkphotography.co.uk
I suggested - and then backtracked - on adding a section on lens design and large format lenses to my least read worst seller. For reasons I may explain later - a direct result of a visit to a Steyning Art Trail location recently - I decided to revisit the idea.
It's not written yet, but I have roughed out a preliminary set of headings/topics to cover, and a reasonable introduction to books on optics from a photographer's point of view. I'm copying it here in case anyone wishes to read it, see where I'm going, and comment on what I should include that I don't appear to have covered. It's laid out in the sequence I envisage the final draft to be. Comments may include "don't bother", so feel free to express that view if you wish
Books
In 1900, in the introduction to his translation of Otto Lummer's Contributions to Photographic Optics, Silvanus P. Thomson wrote (his italics):
"The simple reason of the badness of almost all recent British text-books of optics is that, with the exception of one or two works on photographic optics, they are written from a totally false standpoint. They are written, not to teach the reader real optics, but to enable him to pass examinations set by non- optical examiners. The examination curse lies over them all."
When I was a student, the optics text at my university was Richard Longhurst's Geometrical and Physical Optics. In the preface to the first (1957) edition he says that it was written "primarily for students reading for an honours degree in physics" and may therefore be assumed to align with the topics then covered in a physics degree. The contemporary Light by Robert Ditchburn fits the title well, being more concerned with light per se than optics.
The modern text books on optics can fairly be said to cover the courses taught in British (and presumably) American universities, and this has moved on. Sixty or seventy years ago, when the two titles I just referred to were first being written, topics like quantum optics and lasers were not in the standard texts, and were the province of separate books confined to the topic. As an example, a book I've just pulled from the shelf in front of me, T. P. Melia's An Introduction to MASERS and LASERS (capitalisation as in the book title) of 1967 has the following statement in the preface: "Though in the past few years several excellent books and numerous articles have been written on the subject of masers and lasers, there is still a need for an elementary introduction to the subject which is intelligible to the average science undergraduate".
To allow the introduction of modern topics of interest to researchers (and prepare students for topics being actively researched) material previously covered in the standard texts has had to be reduced in scope or cut out completely. Longhurst in the introduction to the third edition (1973) lists the new inclusions, and where discussion has been cut on older topics. It makes perfect sense; if information can be readily found in earlier standard works that should be available in the (university) library, why include it at the expense of topics that are being actively studied in research labs? And so, we see a steady shift in emphasis.
The main conclusion I want to make from this overview is that, for a photographer, the older books are often more relevant. What may be regarded as THE major modern standard work, Born and Wolfe's Principles of Optics starts from the first page with Maxwell's equations; and if geometrical terms like sines, cosines and tangents are off putting, divs, grads and curls will be a total turn off. Photographic optics - optics for the photographer - can omit this level entirely. And the practical application is this; I referred above to "earlier standard works" and if you note the date from which this shift began to happen, it will be clear that many highly relevant books will be out of copyright, and can be found on the Internet Archive, with either a free download or the ability to borrow.
I normally prefer to give not just conclusions, but the reasoning and evidence that support those conclusions. In this chapter, I'm setting that aside, and have no intention of giving anything more than an overview, but I do intend to give pointers as to where further information and detailed proofs can be found. Fortunately, as indicated above, this can be done using older texts that should not require any expense to download and read as they can be found on the Internet Archive. I shall give links to each title where possible.
On lens design specifically, the advent of computers has shifted what it is practically possible to do; simplifications that reduce very significantly the amount of calculations to be done are no longer needed, and programs reduce the lens designers work. However, for the purposes of knowing the principles, this can be ignored - which is just as well given the cost of some modern books on lens design. But even here, the Internet Archive has books available to borrow.
Light
Waves
Particles
Physical optics
Diffraction
Polarisation
Geometrical optics
In geometrical optics, light is treated as if it were particles travelling along rays in a straight line. It is simpler to use this picture and simple geometry to explain how lenses work and how they are designed, although some properties of light are best explained in terms of waves.
Action at a surface
Reflect
Angle
Mirrors
Parabolic reflectors
Specular reflections
Absorb
Total
Partial
Refraction
Refractive index
Snell's law
Total internal
Dispersion
Scattering
Glass
Types and properties.
Flint and crown
Lens design
Preliminary
Effect of heat
Tolerances of materials
Physical constraints: size, weight, size of standard blanks
Gaussian optics
Assumptions
Defects of spherical lenses
Description of aberrations
1st, 3rd, 5th order aberrations (Lummer, Siedel and notes)
Why no even numbers? Approximations and Taylor series
Approximations
Paraxial rays
Effect of computers
Monochromatic aberrations
Overview of how they are corrected (descriptive only, no calculations), tradeoffs
Petzval sum
Degrees of freedom
Auto corrections of symmetrical lenses
Field flatteners
Coatings and flare
Notes on older designs (properties, considerations in using)
Dagor (gold dot etc.)
Artar (Red dot etc)
Tessar
Repro and G Claron
Why you can get focus shift on stopping down
Convertible lenses
Assessing lenses
MTF
Resolution
Large format books.
So I am seriously considering going Large Format, most likely a Intrepid 4x5 to start with. Looking for book recommendations for large format shooting. More informative books rather then someone's collection of images. So technique, principles and the like. Cheers.
Books
Light
Waves
Particles
Physical optics
Diffraction
Polarisation
Geometrical optics
Action at a surface
Reflect
Angle
Mirrors
Absorb
Total
Partial
Refraction
Refractive index
Snell's law
Total internal
Dispersion
Scattering
Glass
Flint and crown
Lens design
Preliminary
Effect of heat
Gaussian optics
Assumptions
Approximations
Paraxial rays
Effect of computers
Petzval sum
Degrees of freedom
Field flatteners
Coatings and flare
Artar (Red dot etc)
Tessar
Repro and G Claron
Convertible lenses
Assessing lenses
MTF
Resolution
