RaglanSurf
- Nick
I've just taken delivery of an OM4 and it appears to have some problems and Im not sure if they're terminal or curable with a little help from the tapping stick.
When it arrived it had no batteries so I popped a couple in and the shutter returned to its correct position.
I used the battery check lever to make sure it had power, that worked.
I stuck a bog standard 50mm lens on the front, set it to auto and the shutter is open for far too long. If I put it in manual the shutter speed does seem to vary but probably at about 30% speed across the range.
I've had a varity of OM's over the years and they've always been pretty much bomb-proof so is it likely to loosen with use or shall I just return it whence it came and get a refund?
