Noise Reduction
jeet
Hi
I need a bit of guidance about using noise ninja. I tried using it but wasnt mu h succesful. Can anyone tel me the basic changes i need to do o reduce noise.
What software are you using?
The best noise plugin for Photoshop is Topaz Denoise, download and install, you will then find the Topaz Denoise under the filter tab in p/shop, use the default setting first and see how you get on.
I found Noiseware pro better, I did a comparrison test a while back (posted on here but cant find it now) comparing most of the noise reduction softwares and from what I could see noiseware came out about the best.
+1 for Noiseware. Dead easy to use as a plug in, and you can use the stand-alone community edition free to see if you like it. The plug-in cost me around £30 if memory serves; there was a discount voucher that could be Googled.
I know it's a mine field out there, but I find Topaz works with my D1 and D1x images well using PS, Lightroom 4 is good with the images..
