Noise Ninja help
stokecity_m
Chris
I've installed noise ninja, but it doesn't seem to have any profiles, and one got any idea how to get it working?
Cheers
cheers - i've download the files - but where/how do i put them into noise ninja?
To install noise profiles for use with the automatic profile loader in Noise Ninja 2, follow these instructions:
From the list below, download the file for your camera or scanner. (Do not place it in Noise Ninja's NoiseProfiles directory.)
Unzip the file or files that you downloaded. This should produce individual noise profiles, each with a ".nzp" file extension.
Start Noise Ninja and select "Install profiles..." from the Profiles menu if you are using the plug-in and from the File menu if you are using the standalone, and then select the directory that contains the unzipped noise profiles. Press the "OK" button. Noise Ninja will scan the directory and subdirectories looking for profiles, and it will copy any profiles that it finds to the correct location in the NoiseProfiles folder in the Noise Ninja installation directory.
If you are using the plug-in you need to setup Noise Ninja to auto-load the profiles you have just installed. First, go to the Noise Ninja menu and select Preferences. Set the Profile policy to "Auto-load profile based on EXIF." And set the Fallback policy to "Invoke automatic profiler" then click OK.
Perfect - thanks a lot :)
