Nissin Flash Gun Di622
Wayned
Wayne Dicks
A bit skint at the moment as is the Missus and I'm being asked what I want for Chrimbo.
I can't ask her for a Canon make flash gun as it's a bit steep for her.
Anyone with any experience of the above flash unit? They are under £80 on Ebay (From King Kong)
I have a Canon 400D.
Thanks in anticipation.
I had this for a while, found it to be alright, really depends on what your using it for. I used it a lot under low light and it wouldn't focus, under normal conditions it will work fine though. Hope this helps.
I've got one and find it quite good, it is powerful, has some good adjustment, uses the TTL system and is fairly quick at recycling. Be warned though, if you plan on using it with EBay slaves, make sure you get ones that will fire it, as some won't.:thumbs:
Thank you for your help. It would be used for all situations from family stuff to me trying to improve techniques.
