BIGEYE
- Jim
I have a Canon 60d camera and want to fire a Nissin Di866 Pro MKII wirelessly as a remote flash without the pop up flash on the camera. The flash mounted remotely works just fine when I use the camera's popup flash, but doesn't fire without the cameras popup flash. I have tried setting the Nissin in master & remote settings, but this has made no difference.
Here are my settings:
Camera Menu - Flash Control
Flash Firing : Enable
Built In Flash Func Setting
Flash Mode : E-TTL II
Shutter sync : 1st Curtain
E-TTL II meter : Evaluate
Wireless Function Set at remote flash (tried popup & remote setting, this works only when popup flash operates)
Channel : 1
Firing Group : All
Flash Settings
From the main menu select Wireless
Master settings
Channel 1
A - Master
Tried with the Remote settings as below
Flash Setting - From the main menu select Wireless[/U]
Remote settings
Channel 1
Group A
The flash and camera are 100% compatible and the flash is new. I have also tried with the MkI version of this flash and cant get this to work either. Appreciate any help in trying to get this to work.
Channel : 1
Firing Group : All
Flash Settings
Master settings
Channel 1
A - Master
Remote settings
Channel 1
Group A
