- Brian
Anyone done a bodge to fix the fairly common dreaded cracked battery housing at the bottom, the crack is around the terminal so when you put batteries in the terminal moves down and touches something which shorts out the batteries (even camera switched off).....of course the meter doesn't now work. A new battery housing is as rare as hen's teeth and I have the choice of taking the battery housing out
and bodging it or just don't use the meter.......so if someone said "I've taken the battery housing out, bodged it, and it's easy peasy" then I'll do that otherwise will use the camera without a meter.
