jackgilbert89
- Jack
Hey all.
I purchased a essentially as new D90 2nd hand of a user on this website a few months ago and it's been fantastic.Usage has mainly been on a 17-50mm F2.8 Tamron (non-screw driven), some use on 50mm F1.4 AF-D which I sold to get the 85mm F1.8 AF-D. It was working fine focusing accuratley for quite a while.
However something seems to have developed a fault. Essentially the camera/lens will not auto focus accurately.
I have done tests on the 85mm using AF-S, tripod, remote trigger, F2.8 in good light on a focus chart and it is always focusing further back than it should. I know this because I can use live view, and zoom in and the focus is way sharper than when the camera uses AF-S.
The tamron seems to focus fine.
I have tested this using my brother's 50mm F1.4 AF and the problem is still present.
I have tested the 85mm on my brother's D300. It focuses accurately (as does the 50mm)
I have noticed that there is a very very slight rattling in my 85mm, which seems to be a very slightly loose rear element.
There seems to be many other D90 users with similar problems by looking at flickr discussions.
I found an article on the D70 and backfocusing, with a tutorial on correction
Everything seems to point at the camera. Has anyone tried correcting this?
It seems very simple and hard to justify sending to nikon for what will prob be a long time due to post etc.
Other thoughts welcome on this issue!
Thank you!
Thank you!
, is here ...
. Anyway, that will already be factored into the selling price and probably won't amount to very much, per unit.
- it's great!
