- Luke Woodford
- No
Simple question- Why the £400 price difference?
For starters,one is made of plastic and the other metal.....
size of the glass? amount of parts?
I suppose, its just hard for me to see where the extra £400 comes from, i do understand it is bigger and better build quality. Does it produce better quality pictures than the 50 in any ways?
Maybe you should be comparing two similar lenses...i.e the 50mm 1.4 and 50mm 1.8?
I dont know why? i have a 50mm 1.4. I was thinking of investing in the 85mm1.4. I was just wondering why there is such a price difference, i understand now that the build quality is better and there is more to it but is part of the £400 difference because it can produce better pictures? For example if i took the same picture with both these lenses would there be any difference? Apart from the subject being closer of course.
Im new to this and just simply wondered why a lens 25mm difference was £400 more expensiveSo why does the 300mm 2.8 cost more than a 50mm 1.4? You can't compare lenses in the range on price like you're doing, as each lens is different.
The 85mm is a much more complicated lens to make, has a lot more material costs, and is just a very special lens. I don't have the 50mm 1.4 yet to compare the 85 to, but it's definitely, no question, the best lens I own.
Personally, forget all this talk about nifty fifty, EVERY Nikon shooter should have an 85/1.4
Pete
