Hi
I just wondered if anyone had any ideas or ever had a problem like this.
Using a Nikon 17-55mm AF-S F2.8, when I turn the camera on it loses all power. Turning off and on doesn't get it back, and the only way to get it back is to remove the lens and battery, and re insert the battery. As soon as you re-attach the lens and turn on it does the same.
Its the lens thats the problem as I've tried other lenses on the body and they are fine, and the problem occurs on other bodies if I attach the 17-55.
