Hi everyone im new here! Im after some advice ive just got an EOS 400D and i want to take longer exposure photos off streams waterfalls etc, whats best to use an ND filter or Grad?
Could these also be used to take scenery shots ie capture cloud detail?
Thanks everyone!
Welcome to TP
An ND filter and an ND Grad are completely different, and used for completely different purposes. ND Grads are for darkening skies, but that's not what you're asking.
A straight ND filter is used to reduce the exposure. The common application is to make the shutter speed longer so you can do those milky waterfalls etc you're talking about, but they're also good for using in bright light when you want a low f/number for shallow depth of field effects but the camera runs out of high enough shutter speeds.
They come in various strengths, and are often marked in different ways relating to stops of reduction of light (a 'stop' is any halving or doubling of exposure). So a 1 stop ND would reduce the light by 50% and might be marked x2 which is the exposure factor, or 0.3 which is the optical density; 2 stops would be x4 or 0.6; 3 stops x8 or 0.9. Note this last one which is quite common and people think it's 8 stops but ND8 is only three stops. They go right up to 10 stops which is x1024 or 3.0.
So the one you want depends both on the brightness of the daylight and the effect you want. Waterfalls and fountains move quite quickly and 1/4sec will often give quite a blurred/milky effect. If it's not too bright, you might be able to get that without any filter by using the lowest ISO and a high f/number. Or a 3-stops ND8 will probably be okay. Lots of these around.
At the other extreme, if you want to turn the sea to milky glass, have clouds streak across the sky and make people disappear from busy streets, then you'll need a very long shutter speed running into tens of seconds and a very dark ten-stops ND1000. That will reduce a normal exposure of say 1/125sec to eight full seconds, for example.
There are really only three of these really dark NDs worth getting. The B+W 110 is popular (screw fit) or the Lee Big Stopper (square mount) - they're both ten stops. The one I use is a LightCraft ND500 which nine stops, but I prefer it because it's multi-coated and cheaper - 77mm screw fit only though, from Premier-Ink (v good supplier) here
http://www.premier-ink.co.uk/photog...raft-workshop-77mm-nd500mc-filter-p-2927.html
The other alternative is to use the glass from a welding mask, which can be had on ebay for about two quid! They're a bit of a faff to fit and use, but they do work if you want to play, and they're very dark - typically 10-15 stops.
There are lots of thread about using these very dark NDs and the welding glass if you run a search.
