Box Brownie
- No
Hi all
My newly completed build was seemingly working well.
It had been on most of yesterday but I went back to it to find a BSOD with.,
Stop code: WHEA_UNCORRRCTABLE_ERROR
rebooted OK and ran SFC /scannow with no errors or integrity issues
I rebooted to access the BIOS to disable the annoyance of Gigabyte Control Center nagging me to be installed.
After doing so and booting to Windows it threw the same BSOD and a restart did the same even before Windows login.
Another restart resulted in the "Windows Boot Manager" screen with error 0xc0000001
NB very oddly the monitor appeared to lose power so swapped the mains cable and all good......though (forgive forgetting at which point) the original cable was fine.......but something threw the monitor into behaving oddly. I feel this is a red herring
Starting PC I could not even get into BIOS as the screen was reporting "no signal".
Thinking my RTX3060 had a fault I removed it and used the onboard HDMI to the monitor but still no signal.
Note : these latter attempts to start the PC results in it shutting itself down after approx 2 mins.
Note the start up diagnostic LEDs cycle as usual and turn off as they should to illustrate that all is well!
I am kind of at loss now as to what the cause could be......???
Is it the boot drive that suffered a catastrophic failure?
I could take it out and put it in the caddy and examine whether it is accessible or not???
If accessible is it worth re-running the clone process to 'start again'
If inaccessible, that looks conclusive, yes?
If the boot drive is apparently sound, I have a spare old HDD I could use (temporarily) to clone the original source onto and give that a go.
Or is it 'worst case scenario ' the motherboard that has failed.
As it stands I am stumped.....as to what steps I can take to diagnose the fault. I try to take an empirical approach but as per my story above I am unsure what steps I need to do next???
TIA for your insights and suggestions
