foodpoison
- Sean
Firstly, bought the 10-20mm Sigma.
Reason I didn't put this in the other thread is it wouldn't get any attention
So, a couple of weeks back, I ordered some filters from 7DayShop, their own ones, a CircPol and 2 UV's. Work perfectly, pleased with the results.
Will be ordering a 77m Circular Polariser for this lens, but I have seen they also do their own neutral density screw in filters, but was recently considering the Cokin slide in filters.
I have four questions.
1. Will the screw in filters produce any vignetting or encroach on the visible sections of the lens, due to the huge wide angle of the lens?
2. Will the Cokin filters produce better results than the screw in filters (at a guess)?
3. What size adaptor will I need if I were to get the Cokin filter set? Would I need the 77mm adaptor ring and the P series (for lenses up to 84mm) or Z-Pro series (for lenses up to 100m)? (Bearing in mind I'll be using it on the kit lens (58mm) as well.)
4. I'm going to be using this mainly for the alps, and possibly use it some other times when I want long exposures, so what Neutral Density filter will I need?
