Need help regarding layers
Sulai
George Tull
Hey.
my question is this:
In Photoshop CS3 is it possible to take the layers from one edited image and duplicate them to more than one image at a time?
my sequence is over 300 frames long as it is a real pain to keep having to - right click on an image - then click duplicate layer - duplicate layer to which file - then save.
any help?
Two ways spring to mind.
1- write all the layer editing of the original as a action then use the batch command to apply it to the other images.
2-open the original layered image and a dozen other (unlayered) images then control click the layers of the original and drag them across to the other images ,you can drag as many layers at once as you want to another image. Quicker than your method but not as quick as no1 if you are comfortable using actions and batch commands.:)
