OK, new to the forum. But need some technical advise.
I need to zoom into a close subject (about 1 -2 meters away). ideally with a 300+mm focal length. But i need a deep depth of field (the back and the front of the model both in focus). 15cm depth of field would be ideal. Would digital compacts be better at this then SLRs due to their small sensors? If I am not mistaken smaller sensors mean greater depth of field? actually i want to take many images of the same model and then merge them into one super detailed image. She will be sitting very still. I have tried this with canon 400d with a tamron zoom set to 250mm, studio lighting, f14 but depth of field was very shallow. I could move closer with a smaller focal length. does that help? or is the smaller focal length offset by the shorter distance to the object?
Now I am thinking of trying with a canon compact superzoom. Maybe a powershot sx210. are all compacts built with the same size sensor?
The end product will be a close up of the model by stitching maybe 20 pics together. 150 megapixels if i am lucky. thanks
