Need another loooong cable; Triple phono to mini jack (20+ metres)
Messiah Khan
Santa is your dad
Alasdair Fowler
Since you guys were so good at finding me a long USB cable; I am now in need of a long (20 metres or more) triple phono to mini jack cable. Its to go between a video camera and a video editing box. Going to need 4 of them so the cheaper the better. :)
Your best bet may be something like this and then one of these.
Obviously the signal loss might be quite high on such a long run - so you may want to try and source some good quality extension leads.
Hope this helps.
Yeh, I was gonna say if you can get hold of one of those 4-way 2.5mm jacks then I'd happily make you a cable loom, but I think what you've found there should do just fine.
If you're suspending cables anywhere then be sure to tape together any connections. Ten minutes before the start of a performance I was lighting for a local village theatre group I had a connector decide to dislodge itself above the audience and had to quickly shin up a step ladder and tape it all back together and get the projector to stop showing a nice blue screen with "NO SIGNAL" on to the curtains!
Do drop me a PM if you need any cables making up.
