need a little help in the right direction
bigtodski
lee
i have taken a couple of pictures of a kitchen we fitted but a bit of plaster is missing and i need to be able to fill the hole i have lightroom 5 on my laptop and work has photoshop but i haven't used it much so a bit stuck .
the hole is above the byfold doors
http://www.flickr.com/photos/bigtodski/9094499787/
if you could point me in the right direction thats all i need (well for now)
ps just ignore the clutter
cheers for the help
My first thought was the clone tool in photoshop, , alternatively I think a simple copy and paste job from the surrounding area would cover that up quite nicely too.
thanks i new to photoshop how do i do a simple copy and paste do i just make a box then ctrl c then ctrl v
Nice kitchen!
Agree with above. select similar to what you want above the doors. Feather Press ctrl J and select move tool and move a plastered piece over the unplastetered piece. Flatten image
With the clone tool you can start with a soft brush and start cloning it out until you get close to the bottom of the hole where theres a straight line, here I would change to a hard brush to keep the edges straight.(using the shift key)
You can also use the marquee tool just above the hole to make a selection of about the same width then use the warp tool and play around that way (edit>transform>warp).
The content-aware might work too if you manage to make a selection around the hole with the lasso or magnetic lasso.
There are other ways of doing this, I just mentioned the ones that popped to mind, I would see which one works best. If you need any help put the img up for download or send it to me and I'll give it a go.
thanks for the help the clone brush seems to give the smoothest cover up
more practice needed
